Pop up window when being in zoom which says that it is not possible to stablish a safe conection
Since today I have had a pop up window saying that it is not possible to stablish a safe connection with zoom . If I click on " open certificate " it appears the following" DigiCert Global G2 TLS RSA SHA256 2020 CA1 "error code 6: The Certificate from DigiCert Global G2 TLS RSA SHA256 2020 CA1 is not safe" This message is issue for *zoom.us , Organization: Zoom video Communications Inc.  Series Number: 06 E4 51 35 FO 63 AA C59B 1C 32
EE 46 C7 35 8 E .
Issued by: DigiCert Global G2 TLS RSA SHA256 220 CA1  Organization: DigiCertInc
And if I open the browser I can connect but still the pop up window continues poping up.
Last week when I logged it appeared that there was a new update, but I didn't update my app, could this be the reason of this popping up window today?
My PC operating system is Windows 7.
Thanks , I need someone to tell me what to do in order to be able to continue having my online meetings.
Regards,
aceenglish
    Hi @aceenglish @Mauricio1977 @Massimiliano @nom234 @MTDarulHikmah, welcome to the community! This issue you are facing could be resolved by a couple of things:
    First, would suggest Uninstalling and reinstalling the Zoom application downloading the latest version of Zoom
    Second recommendation, I would verify the following firewall rules are in place for certification validation with Zoom. More information here
    The Zoom client 5.5.0 or later requires allowing the following URLs for certificate validation.
    Protocol Ports Source
    Destination
    HTTP 80 Zoom client crl3.digicert.com
    crl4.digicert.com
    ocsp.digicert.com
    crl.entrust.net
    certificates.godaddy.com
    crl.godaddy.com
    ocsp.godaddy.com
    certificates.starfieldtech.com
    crl.starfieldtech.com
    ocsp.starfieldtech.com
    Thirdly, after configuring firewall and reinstalling, this may need to be handled by our Zoom Support team, as it looks like they're gathering logs for similar issues if you're unable to configure firewall rules successfully.
    Let me know if this helps!
    have same problem within domain environment on win10 machine
    if we try to log in using zoomacc(at)example.com at machine M and AD user domain\username - we get that error
    if we try to change AD user on same machine or try to login same AD user on other machine (same Zoom account) - we log in Zoom successfully
    already tried:
    • clearing %userprofile%\AppData\*\Zoom
    • reinstalling Zoom client
    I have the same problem since a few days and installing new certificates did not help, my firewall is unchanged and I can log in on the website. Is there any solution available apart from installing a new system?
