Pop up window when being in zoom which says that it is not possible to stablish a safe conection | Community
  • April 3, 2023
  • 13 replies
  • 47 views
Since today I have had a pop up window saying that it is not possible to stablish a safe connection with zoom . If I click on " open certificate " it appears the following" DigiCert Global G2 TLS RSA SHA256 2020 CA1 "error code 6: The Certificate from DigiCert Global G2 TLS RSA SHA256 2020 CA1 is not safe" This message is issue for *zoom.us , Organization: Zoom video Communications Inc.  Series Number: 06 E4 51 35 FO 63 AA C59B 1C 32
EE 46 C7 35 8 E .
Issued by: DigiCert Global G2 TLS RSA SHA256 220 CA1  Organization: DigiCertInc
And if I open the browser I can connect but still the pop up window continues poping up.
Last week when I logged it appeared that there was a new update, but I didn't update my app, could this be the reason of this popping up window today?
My PC operating system is Windows 7.
Thanks , I need someone to tell me what to do in order to be able to continue having my online meetings.
Regards,
aceenglish
    I'm having the same problem as you. Hope they can help. Right now i cannot sign in in zoom.
    Yes, it happened all of a sudden. I tried to download Google Chrome again cause may be that was the reason of this sort of problem, but there was no change 🙄
    Hope anyone from the Support team can help us!
    Greetings form Argentina.
    aceenglish
    Ana
    I'm having the same problem on my laptop also.
    Hoping that they will solve the problem ASAP
    The same problem
    I also have Windows 7 and it also gives the same error
    Yes I am having the same trouble. tested 3 computers and had the same issue on all of them. it is only happening on windows 7 computers. I eventually joined my meeting late by using a windows 10 tablet... but it was well over an hour of frustration trying to fix the issue and camera doesnt work on the tablet so I still need to fix Zoom on my main computer.
    I am having the same trouble in win 7
    Same problem, PC with Windows7
    Please ZOOM: fix the problem!
    O meu também prezados, peço ao Zoom sulução rapida para windons 7
    I fixed the problem on my computer by installing windows update "windows6.1-kb4038777-x64" which I got from this site https://eu.wargaming.net/support/en/products/wot/hot-issues/35560/ . I dont know if it will help anyone else but if you are as desperate as I was, you might like to try it. I had no idea what I was doing. I was just downloading that update for someone elses computer to fix their game of WoT and thought "why not try it on my laptop to fix zoom?" It worked perfectly. I have no idea what it is actually for, so use at your own risk 😉 I also tried the other update listed on that page but it did not do anything, lol, like I said, I was desperate. 😄
    Thank you, but the Microsoft update listed on this game's page was already installed on my PC, yet Zoom still doesn't work...
    The same thing happens to me, the problem is that when I have Win 7, Chrome no longer updates and that is why the error appears in the zoom certificate. When I start my chrome I get a message that as long as I have Win 7 I won't be able to update it. If someone knows the solution, please tell us, because if I install Windows higher than 7, my laptop gets slow.
