Jul 27, 2023 8:16 AM UTC
Whiteboard resizes when I double click
I have used the zoom whiteboard on my iPad extensively for the last year or so since it was released, however something weird has started happening across the last week.
if I draw using my Apple Pencil then it sometimes interprets my writing/drawing as a double tap, and it the automatically resizes the whiteboard eg from 100% to 125%.
I cannot find any way of disabling this double tap irritation.
it also does the same if I access the zoom whiteboard via the zoom website rather than through the zoom app.
if I use the old zoom whiteboard the problem does not happen BUT it is not as smooth an experience.  I really like the zoom whiteboard, but the double tapping resizing issue make whiteboard use in online lessons unusable.
please help!!
Aug 2, 2023 9:57 AM UTC
hi @Mark27 we will fix it as soon as possible
Mark27Author
Aug 6, 2023 7:45 PM UTC
Hi
any idea on timescale to fix this problem? It is making the ‘new’ whiteboard un-usable. I am having to use the old zoom whiteboard.
Aug 7, 2023 12:45 AM UTC
sorry, if we deploy the fixed version, I will let you know.
Sep 17, 2024 10:41 PM UTC
The whiteboard jumps all around when I am using the apple pencil. It is impossible to draw shapes when teaching geometry. Help!
