Apr 28, 2025 4:48 PM UTC
Whiteboard AI problem (Zoom AI Companion)
I can't use AI on the Zoom whiteboard I created before becoming a premium user. It says upgrade your plan. I upgraded my plan today 🙂 I can use AI on documents but I still can't use it on whiteboards. It still says upgrade your plan for whiteboards. And it doesn't use AI on the new ones I create either. Locked!
AlexMa581
May 1, 2025 9:54 PM UTC
Hi @ceng74 ,
Wondering could you use other Pro whiteboard feature. for example, private mode? Just want to check if all pro features are disenabled for your whiteboard or only AI.
Jun 2, 2025 6:56 PM UTC
Hi @ceng74 , we recently updated our access policies. Let us know if you still have issues accessing AI features in Whiteboard!
