Feb 8, 2023 9:39 PM UTC
Is it possible to copy and paste outside info onto a whiteboard?
No text available
    Feb 19, 2023 5:05 PM UTC
    hi jvaughan,
    you can copy and paste outside info onto a whiteboard.  for some unknown reason, right click on the mouse does not work.  on your whiteboard, use the ancient ctrl+v method (at the same time press the Ctrl key and the v key).
    thanks,
    eliot
    kkonzack
    Jul 6, 2023 9:15 PM UTC
    This did not work for me  😞
    I am having a really hard time and need this capability!
    Jul 8, 2023 2:23 PM UTC
    hi kkonzack,
    please try ctrl+c or right click and copy for copy outside info and ctrl+v for paste into whiteboard.
    i just tried it with Zoom windows client 5.15.2 and it works.
    if it does not work for you, which of the zoom whiteboards are you using, what is the client version and what is your operating system?
