Jul 25, 2024 11:15 AM UTC
ZoomEvents - Automatic Recording doesn't work
in my Event configuration I have selected the option to record the event directly when the event is started. It should be stored on my local PC.
But, when the event is really startet, the recording doesn't start as expected. Starting it manually was working. But I expected it to be started automatically.
Is there any setting I have missed?
Best Regards
Björn
    DeniseLahat
    Jul 26, 2024 1:46 PM UTC
    I recommend to record to cloud and not local.   But can you confirm that you selected Automatically  start recordings - on local computer?
