Italiangen2022
Contributor I
Contributor I
Jan 22, 2024 5:59 PM UTC
Audio settings exclusive mode
I am still unclear when or if I should enable Exclusive mode while on Zoom.
My setup is W11, simple USB audio mixer for mics and standalone speaker output, webinars using screen sharing, YT video via G-browser, and mp4 files.  What does Zoom recommend?  I've read a few posts and MS definitions but is still unclear.
Thanks for your help.
IGG
    Jan 23, 2024 4:18 PM UTC
    Hi, @Italiangen2022.
    This is more of a Windows question than a Zoom one, but I do see where you'd be concerned with Zoom usage of mics or speakers regarding this setting.
    I rarely enable the Exclusive mode of any sound devices.  I don't want any one application to take full control over a mic or a speaker, as I'm frequently using a mixer (like Voicemeeter or the audio functions within vMix) or wanting to use audio from one device to go into multiple other inputs.  So unless a manufacturer or software package says "always use Exclusive mode or this won't work", I leave it disabled.
