2025 CMX Awards
Vote now
Zoom Room Display and Camera set to Auto Framing seems blurry
NCTEXAN
Hello!  New here.
When in a meeting Zoom Room Display and Camera set to Auto Framing seems blurry on the screen while in a meeting and sharing content from laptop in the Zoom room.
Any suggestions most appreciated.
1 ACCEPTED SOLUTION
bstrelko
Unless you're using a camera that supports optical auto-framing (90%+ don't), Zoom is merely stretching/cropping your camera's image to re-frame participants, which will typically look rough.
Your camera is not actually zooming in on the participants, which means you're just taking the pixels you already have from the wide-shot and making them bigger - this will rarely ever look good (unfortunately, this has become the norm in 2024).
I'd ask for a screenshot without auto-framing enabled, and then with, just to confirm whether this is the actual issue.
3 REPLIES 3
bstrelko
Bri
Hi @NCTEXAN , did you see the reply provided by @bstrelko ? Please let us know if you found it helpful!
Bri
Zoom Community Team
ITADCOM
Camera supports zoom, but since you're using Zoom drivers, it will not zoom.
