Aug 13, 2021 2:51 AM UTC
Waiting Room Sound on Entry
Participant tab ... gives the option to make a sound when a person enters the waiting room.
I would like this to be permanently on, so I don't make people wait because I am looking at another screen.
It looks like I have to enable sound on entry every time I start a new meeting.  Can this be made a default?
Thanks
    RtulipAnswer
    Aug 13, 2021 7:56 AM UTC
    Thanks very much, that worked.  It surprises me I could not find this in any Zoom help searches,  I need this as I often leave people waiting to join small meetings as I look at other screens such as email while I am hosting.  I had some confusion finding this function, as https://zoom.us/profile/setting is at Personal, and not under the profile menu, as its url suggests it would be.
    shahbaz63
    Aug 13, 2021 5:29 AM UTC
    This might work: Go To Profile setting on Zoom.us and navigate to the "Inmeeting (Basic)" option from the left tab and enable  "Sound notification when someone joins or leaves" you can select play sound for "Host/ Co-host or for everyone".
    Personal Tip: Select host/ cost only, to avoid disturbance to participants.
    RtulipAuthorAnswer
    shahbaz63
    Aug 13, 2021 8:56 AM UTC
    Happy to help!
    Jan 6, 2025 11:31 PM UTC
    I have changed this setting but I still don't hear when someone enters the waiting room.  I have changed it in all of my Zoom profiles and it isn't solved. Please help
