Is there an audio notification for waiting room attendees? | Community
  • July 9, 2024
  • 19 views
Hello Zoom Community!
I host a number of Zoom calls and I'm always a few minutes early in advance of these calls. While waiting for my attendees, I'm usually using other apps and/or browsers on my computer that are on top of the Zoom app, which means that I need to keep switching back to the Zoom app to see if an attendee has entered the waiting room, which can become tedious.
It would be great if there was an audio notification that regardless of the app you're using, would alert you that someone's entered the waiting room to get on the Zoom call.
If this audio notification is available, please let me know where to find it. If this notification isn't available, it should be.
@rscharf - There is an option to turn on audio notifications, but I have not had an opportunity to test if it works when attendees are put into a waiting room.
