Unsupported analog adapters? | Community
BrandonS
Community Champion | Partner
January 3, 2022
  • January 3, 2022
  • 14 replies
  • 205 views
I am a reseller/installer and need to get an analog fax working, but the only supported adapters from Audiocodes and Poly are not possible to obtain currently due to supply chain issues..
I have searched, but not found info on trying to get unsupported SIP devices working.  Is it possible at all or if not on the official supported list, no chance?  I want to try a Grandstream HT801 that I was able to get.
https://support.zoom.us/hc/en-us/articles/360001299063-Zoom-Phone-Certified-Hardware#h_01FGMSZR5KEY4PDC1B03VJSX6Z
Thanks!
    Best answer by Arps
    Hi Brandon!
    Please reach out to the customer's Zoom account team.  There is a way to enable provisioning of generic sip endpoints, but the customer must work with the account team to have this enabled.  Due to support issues, it's not enabled by default on phone accounts.
    Rick
    Arps
    ArpsAnswer
    Hi Brandon!
    Rick
    BrandonS
    BrandonSAuthor
    January 3, 2022
    Thanks for the reply.  I am chatting up support about that right now.
    Participant
    February 17, 2022
    HI THERE!
    How did this go? Did you get the Grandstream working?
    BrandonS
    BrandonSAuthor
    February 17, 2022
    Yes.  Just replied to your other post before seeing this.  The downside was it took a couple weeks of back and forth with support to enable generic SIP devices.  Maybe now they can approve for you faster.   Hit me up and I can look for my case number to reference if you go this route.  Good luck.
    Participant
    March 14, 2022
    Hey Brandon. Wondering if you have your provisioning config handy for the Grandstream device? I am stuck on what to put where in the Grandstream  configuration page. thx!
    BrandonS
    BrandonSAuthor
    March 14, 2022
    Hmm.  I did keep these notes, but don't have remote access to the device now.  I had to enable TLS and maybe download some certificates and upload them to the GS?
    (sanitized some info)
    Provisioning
    MAC Address
    c0-74-ad-AB-CD-EF
    Device Type
    Other
    You will need to enable TLS1.2 for SIP registration and enable SRTP for secure calling on your IP phone. Please refer to your manufacturer's instructions for these processes.
    You'll need following information for manual provisioning.
    SIP Account 1:
    1. SIP Domain: 501123123.zoom.us
    2. Outbound Proxy: us01sip20h.ny.zoom.us:5091
    3. User Name: 79700123123123246
    4. Authorization ID: 3241231231232
    5. Password: haassddffi
    Please download DigiCert Global Root CADigiCert Global Root G2DigiCert Global Root G3 and import to your IP phone if they are not in the trust list of the device.
    Note: Please note that Zoom support team will not be able to troubleshoot or configure IP phones that are provisioned in this manner. Some Zoom Phone features may not work on manually provisioned phones. It may vary depending on your desk phone model.
    Participant
    March 15, 2022
    Thanks, Zoom sent me similar provisioning instructions. I think I put everything in the right spot. I am unsure as to where to upload the 3 certs. I did a copy/paste the first 2 certs into 2 CA sections in the Advanced tab but they won't save. May reach out to Grandstream to see if they are helpful as well.
    BrandonS
    BrandonSAuthor
    March 15, 2022
    I must of been fairly lucky and sorry I don’t recall the exact settings, I should have saved at least for my self  for next time.. when you get it sorted if you remember to share I’ll appreciate it. Good luck.
    Hi, we have the same device.  i think i know how to solve it based on here and support documents.  the one thing i cant find is the sip/server proxy address/outbound proxy.
    i have a zoom room connector license and setup the room. documentation says it should like the outbound/sip proxy address but it only provides username and passwrd
    June 16, 2023
    Provisioning is zero touch provisioning (ztp).
    To provision a Grandstream HT801 ATA, you need to:
    1.  Update the device certificate
    Grandstream_Device_Certificate_Update_Guide.pdf
    2.  Upgrade the firmware
    Firmware Upgrade Guide - Documentation Center (grandstream.com)
    3.  Provision the HT801 by assigning it to a user.
    Screen shot before provisioning
    To provision, add device and assign to user, click Save.  Provisioning is automatic (ztp).
    HT801 - Quick Installation Guide - Documentation Center (grandstream.com)
    HT80x - Administration Guide - Documentation Center (grandstream.com)
    HT801 - Quick User Guide - Documentation Center (grandstream.com)
    Hi Eliot
    Thanks for this helpful guide.
    This helped me guide through the process of auto provisioning a Grandstream HT802 ATA device.
    All is working well and I can make and receive calls.
    But the device now has an admin password of which I don't know. Do you know if that is a zoom restriction or something that maybe set on our org level?
    No template was used to deploy this HT802 ATA device.
    Even now I factory reset it and I can get back in via admin/admin but as soon as it gets on the internet and connects to Zoom servers and pulls the config I get locked out again
