ZTP using for Poly VVX Series phones
Hi
Can I know if anyone has issues today for doing ZTP for Poly phone VVX Series for Zoom Phone?
I have issues that the Poly phone did not upgrade to the supported firmware/software version.
The provision path is https://provpp.zoom.us ...
EliotAnswer
September 16, 2023
hi taikc,
 which vvx model and revision do you have?
What firmware version do you get when you use ztp?
VVX 250/350/450 come with two firmware versions depending on the hardware revision (Old or New). Please review the Poly Product Shipping Configuration Change Notice for more detailed information about new hardware revisions.
VVX 250 Business IP Phone
AES-256
6.4.5.1210 (Old hardware rev)
6.4.5.1251 (New hardware rev)
5/28/2023
(see Note)
VVX 350 Business IP Phone
AES-256
5/28/2023
(see Note)
VVX 450 Business IP Phone
AES-256
6.4.34.3178 (Old hardware rev)
5/28/2023
(see Note)
https://support.zoom.us/hc/en-us/articles/360001299063-Zoom-Phone-Certified-Hardware#
EliotAnswer
September 16, 2023
hi taikc,
AES-256
5/28/2023
(see Note)
AES-256
5/28/2023
(see Note)
AES-256
5/28/2023
(see Note)
TaikcAuthor
Hi Eliot
Thanks for the advise. I am working with VVX411. It is the same firmware version used. Currently out company is deploying 6.4.5.1210.
September 17, 2023
hi taikc,
i tried with one of my vvx411 that i had not used since april 2023.  when i plugged it in, the vvx411 it automatically upgraded firmware to 6.4.5.1210.  i removed the vvx411 from my account.  i did a factory reset and then added the vvx411 back in.  everything worked as expected.
VVX 411 Business Media Phone
AES-256
6.4.5.1210
5/28/2023
Zoom Phone Certified Hardware – Zoom Support
Before rebooting poly vvx 411 had 6.4.4.3178.
After rebooting poly vvx411 had 6.4.5.1210
Removed vvx411, did a factory reset, added vvx411 to unassigned devices and then assigned to user.  Everything worked and had 6.4.5.1210.
maybe zoom or poly fixed something?
