Zoom Phone - Poly EDGE e450 Randomly Rebooting... | Community
  • May 2, 2023
  • 10 replies
  • 195 views
We recently deployed Zoom Phone...we selected the POLY EDGE e450 as our physical desk phone for those that were not quite ready to let go of a physical device...
We are now getting reports that folks phones are randomly rebooting...sometimes mid call...happening in various offices...not at the same time...not on the same network equipment...and not on all devices...just some of them.
We have tried swapping phone, cables, network ports and yet some users still experience the issues...
We have pulled the logs and given them to both POLY and Zoom...
Has anyone seen this issue before?
    Hi BeckyBo,  Take a look at "Call Control" for your specific phone. You can find that under your personal settings for phone or under the Phone System -> choose a user - and check their desk phone. I'm thinking you have call control enabled at the Admin level but it is not enabled at the individual phone. https://support.zoom.us/hc/en-us/articles/4912628206477-Using-desk-phone-call-control
    BeckyBoAuthor
    @flyboy0_15...can you explain how the call control is related? I have made this change on a few of the phones....waiting to see if it corrects the issue...
    I'm just deploying a few Poly e350 phones, and I have already experienced this. I made an outbound call to my cell to test, and when I hung up my cell, the Poly froze, and a minute or so later, rebooted itself. How would this be related to Call Control, @flyboy0_15 ?
    May 4, 2023
    Do you have the current firmware on your poly edge eseries?
    that firmware is
    8.1.1.3281
    thanks. Eliot
    I am on 8.0.0 - but when I go to the menu (settings -> status -> platform -> software update status -> "check now" button), I get an "Update Failed" message. So I am not sure I know how to update the firmware.
    Never mind - I was looking at the wrong phone that wasn't provisioned. The firmware is 8.1.1.3281.
    May 5, 2023
    hi,
    you might try factory reset.  sometimes, this fixes issues with desk phones.
    Resetting to factory default (Poly) – Zoom Support
    May 8, 2023
    poly release notes (attached) for its most recent firmware release for edge e series is 8.1.2.  8.1.2 is not yet approved for zoom and does not seem to address the random rebooting.
    i suggest opening a ticket with poly or have your poly dealer do so.
    BeckyBoAuthor
    our issues are with the EDGE e450 and e320's...we have tried multiple configs from the tier3 support folks at Poly with no success...we are now working to RMA our EDGE phones and move to the VVX450's which we are not having this issue with.
    July 22, 2023
    hi beckybo,
    you might consider updating your poly firmware for edge e series.  i only have a poly edge e 100 which is not experiencing any issues, but has 8.1.2.1128 firmware.
    zoom now has 8.1.2.1128 as the firmware for poly e series.
    https://support.zoom.us/hc/en-us/articles/360001299063-Zoom-Phone-Certified-Hardware
