Zoom Phone - No Inbound Audio - Poly edge E220 | Community
  • August 14, 2023
  • 127 views
We recently setup Zoom phone for our Corporate HQ in Singapore and we are having issues with Inbound audio on a physical phone will receiving a call from an external Dialer.
I am going to summarize and can provide PCAP if helpful
Provider : Singtel
Connection Type: Provider Exchange(OTT Private Data Center)
Physical Device: Poly Edge e100/220
We have an open support case with Zoom but hoping to have community support to assist with faster resolution. We have checked all firewall port settings required for Zoom phone and validated they are opened as needed. We have swapped to new phones of the same model but having the same issues.  We moved the phone number from a Common area account to a user account(logged into a computer) and they have ZERO audio issues.
I know I might be missing some helpful details but can fill in the blanks if anyone has thoughts of things to check.
Call-Out
Call-In
Type of Device
Type of Network
Call notification
Call pickup
Voice
Remark
Call notification
Call pickup
Voice
Remark
Poly E220
Home broadband
Success
Success
caller and receiver can hear each other
NA
No
No
No
Laptop Zoom application aware the external call
Poly E220 & E100
VF Office
Success
Success
NA
Success
Success
No
caller can hear voice. Receiver failed to hear.
August 18, 2023
hi jeremy_haymore,
because audio works with zoom desktop client, sounds like it may be a problem with the poly e100 and e220.
You might try a factory reset on these desk phones.  make sure that poly provisioning ports are open.
Prerequisites | Poly Zero Touch Help
Also, check to see that these desk phones have the current zoom supported firmware 8.1.2.1128 is installed.  I did not see this problem noted in the poly release notes.
https://www.poly.com/content/dam/www/products/support/voice/poly-voice/release-notes/poly-voice-software-release-notes-8-1-3.pdf
