Dec 30, 2023 10:10 AM UTC
Zoom One Pro vs Zoom Phone
Hello
We have a Zoom One Pro account which has been used for the odd conference call only using a mobile device. We now need to move over from ISDN to VOIP with our landline and was wondering if this is possible with Zoom One Pro or do we need to upgade to Zoom Phone. We will of course still want to make the odd conference call as before.
Thanks
nickcccAuthor
Dec 30, 2023 10:35 AM UTC
Actually I now see that this is a feature to add to the existing Zoom One Pro package for additional cost. Perhaps will try on a monthly basis to begin with to see how it works out.
Dec 30, 2023 2:04 PM UTC
hi nickccc,
you are correct.
here are links for admin to set up zoom phone, using zoom phone and certified devices.
Getting started with Zoom Phone (admin) - Zoom Support
Getting started with Zoom Phone (users) - Zoom Support
Zoom Phone Certified Hardware - Zoom Support
nickcccAuthor
Jan 2, 2024 4:27 PM UTC
I just noticed there is an option to upgrade to Zoom Business Pro which inludes Zoom Phone. This appear a cheaper option than adding Zoom Phone as a separate package. Why would that be?
