Partner
Apr 14, 2025 8:02 PM UTC
Yealink T57W Phones firmware is not automatically updating after release
Our T57W Yealink phones were experiencing intermittent audio issues. We found that they were not on the latest Yealink firmware. Instead of 97.87.0.15 that was released March 10, 2025, they were still on 96.86.3.17. The Zoom Chat Agent couldn't explain why they haven't pushed out the latest release, does anyone know?  After I manually updated the firmware on each device through the IP GUI the audio issue hasn't resurfaced.  I just hope to not have to manually update the next time Yealink releases a firmware update.
Apr 14, 2025 8:28 PM UTC
As far as i know, the latest release was processed during the past weekend. Usually Zoom will do an auto pulling (firmware update) for Yealink devices within 3 days after release unless your admin turned off the auto update in your admin portal. You don't need to manually update all of your devices.
pmarkwoodAuthor
Partner
Apr 14, 2025 8:31 PM UTC
Thank you for your reply.  I manually updated all but 2 phones, both of which are still on the previous version.  Can you tell me where to go in the admin portal to check if automatic phone updates are turned off so I can check?
Apr 14, 2025 8:40 PM UTC
For example, the firmware will be locked in 8.2.2.1176 in this case.
Participant
Jun 12, 2025 5:55 PM UTC
Is it fine to upgrade to firmware 96.87.0.15? Or better yet, is it fine to upgrade any firmware early before it is released by Zoom?
