Speed Dial Settings directly on Phone | Community
  • February 16, 2022
  • 93 views
I set speed dial settings directly on my phone before we had zoom software to use.  I have deleted the direct settings, but zoom will not update the locations on the phone that were directly set up.  What is a solution for this problem.
    Not sure what you mean ... you can update / manage keys with speed dials in the Zoom portal.
    here is the guide: https://support.zoom.us/hc/en-us/articles/360036860751-Setting-up-speed-dial-and-busy-lamp-field-BLF-#h_f9a264ea-9821-4cb6-bfcf-02a8ae38d457
