Jul 10, 2025 6:51 AM UTC
Salesforce CTI integration fails to load iframe due to X-Frame-Options restriction
We are trying to integrate Zoom Phone with Salesforce using the Zoom for Salesforce Lightning CTI adapter.
Current configuration:
  • CTI Adapter URL: https://zoom.us/lightning/zoomphone/lightning.app
  • Permissions sets assigned (Zoom Phone User)
  • Zoom Marketplace app authorized
  • Phone number assigned and active
  • User email address matches between Salesforce and Zoom
  • Clickjack protection disabled on Salesforce
Issue:
When opening the Phone component, we get the following error:
Refused to display 'https://zoom.us/' in a frame because it set 'X-Frame-Options' to 'sameorigin'.
Additionally, there is a 404 error:
Failed to load resource: the server responded with a status of 404
Question:
Does this require any special configuration or account-level activation on the Zoom side to allow iframe embedding for Salesforce CTI? Could you please advise the next steps to resolve this?
Thank you.
May 5, 2026 2:31 AM UTC
We ran into a similar problem at our company after upgrading the Zoom → Salesforce integration from v1 to v2, with errors such as:
401 Unauthorized
applications.zoom.us refused to connect.
Framing 'https://applications.zoom.us/' violates the following Content Security Policy directive: "frame-ancestors 'none'". The request has been blocked.
(index):1 Failed to load resource: the server responded with a status of 401 ()Understand this error (index):1 Unsafe attempt to load URL https://applications.zoom.us/salesforce/phone/index.html?mode=Lightning&isdtp=vw&sfdcIframeOrigin=https%3A%2F%company.lightning.force.com&nonce=xyzf&clc=1 from frame with URL chrome-error://chromewebdata/. Domains, protocols and ports must match.
The issue was the CTI Adapter URL. It was fixed via the following steps:
(1) Go to Setup -> Feature Settings -> Service -> Call Center -> Call Centers.
(2) Click on "Zoom Phone".
(3) Change the CTI Adapter URL field to:
As an aside, don’t forget to also configure your Trusted URL in setup:
If you’re talking about Zoom Contact Center (v2.3.0 or higher) and not Zoom Phone, you should instead change the CTI Adapter URL field to:
https://zoom.us/cci/callbar/crm
Source:
