Problems dialing DC/Maryland # from landlines | Community
  • October 3, 2022
  • 50 views
I'm based in the DC area and we have recurring Zoom meetings which all provided the same Maryland number:
Dial by your location
+1 301 715 8592 US (Washington DC)
The number when dialed from a Landline doesn't work (Error received: You call cannot be completed as dialed...). We tested from multiple landlines and none worked.
Other numbers (like NY 646 prefix) work fine on both.
    Quailman
    Hello @Spratticus, Thank you for your post!
    I certainly hope that you aren't facing this issue any longer. If you still need help with your dial-in to Meetings, could you please contact our support team? Here is a link with different support options --> https://support.zoom.us/hc/en-us/articles/201362003-Zoom-technical-support#:~:text=Zoom%20Plans%20an...
    I'm sorry that it has taken a while for someone to provide you with a response. It looks like your posting was added to the Zoom Phone Community, but your inquiry is most likely regarding Zoom Meetings, which is generally unrelated to Zoom Phone unless you are a Zoom Phone subscriber and have dedicated one of your Zoom Phone Numbers to act as "Dial-in" for Meetings.
    I hope this information helps!
    Thanks!
