Poly Edge e220 offline | Community
  • April 11, 2023
  • 71 views
Just getting started with ZP.
I have had 2 of these phoens go bad on me. Meaning i cannot factory reset them as i've had to RMA them.
The first I thought was a fluke.
The second not so much.
Have a Reception phone setup as a shared line group.  The phone is part of this line Group.  When I had it setup it was working properly.  Came back from Easter Holiday and red  x through the line appearance. In the phone on ZP Admin it says "
Factory reset needed for provisioning
This device supports zero touch provisioning. After the factory reset is triggered, the process will take a few minutes, please wait until it is finished. If it fails, try Assisted Provisioning."
The first phone said this then i added a new phone new mac, etc and it sayss the same thing.
Firmware on my working phone is
8.1.0.12774
FIrware on broken phone is
8.00.13670
Any thoughts?
Thanks,
Paul.
Hi @Paul-Varenholt
The certified version is 8.1.0.12774. When you factory reset it should come back to this version. Are you controlling the firmware version using Company Info -> Account Settings -> Desk phone -> firmware ?
