Not Receiving Incoming Calls
Since upgrading my iPhone to iOS 17.5.1 I have not been receiving incoming calls. They are going straight to voice mail.
Is this a known issue and/or is there a fix?
May 26, 2024
hi zardoz,
i do not have any issue receiving zoom calls on my iphone 14 promax with ios version 17.5.1.
i am using current zoom workplace ios version 6.0.10 as of 5/26/2024.
if you do not have the current zoom workplace ios installed, you might consider doing so.
i do not see anything in the ios release notes about your issue.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0069041
