No Incoming Audio - Zoom Phone | Community
  • February 13, 2023
  • 3 replies
  • 91 views
I am having an issue in my home office using Zoom Phone where I am not able to receive incoming audio.  This only happens with Zoom Phone, when I get on Zoom video calls incoming audio is fine.
The extremely strange thing is if I unplug Ethernet from my computer, so I am only on WiFi the audio problem goes away.
Fact everything is fine on Wi-Fi seems to indicate this isn't a firewall issue, but maybe a specific router port setting?
This didn't start being an issue until I upgraded to a new Verizon router, model G3100.  I've configured this router the exact same way my previous Verizon router was configured, so I am at a loss.
Any suggestions that could cause this to be happening?
Zoom is on Version: 5.13.5 (12053)
ISP Router - G3100
Wireless Mesh Router - Amplifi HD
Wired Switch for all hard-wired devices - Extreme X435-24P-4S
    Hi there,
    Seems to be a firewall issue to me. Please ensure your Zoom phone ports are open on your firewall:
    https://support.zoom.us/hc/en-us/articles/201362683-Zoom-network-firewall-or-proxy-server-settings#h_01EEBSGCKBYVB20MCVPR78T0NN
    PKellsAuthor
    This was my initial thought as well when problem started, and did manually open these ports on my firewall...even though I didn't need to do so previously on older Verizon router.
    But fact audio is fine when I'm on my WiFi, I don't believe its firewall related.
    Hello @PKells
    Is the issue resolved yet ? Meanwhile, you can try simulating calls over the ethernet connection and see the scores, that will give you a better understanding. This tool needs to be requested via a support ticket. Here is the article
    https://support.zoom.us/hc/en-us/articles/7814027751821-Simulating-VoIP-calls-using-the-network-tool
    Hope that helps
