Jul 11, 2023 10:29 PM UTC
No dial tone or ring tone on outgoing calls
Zoom Phone users making outgoing calls will not hear a ringing tone or a dial tone. The caller does not think that the call is connecting although it is and is hanging up on prematurely, causing a lot of problems for our clients. This is happening on iPhone app, desktop softphone, using a headset, and without a headset. It's not everyone, with every call. This appears to be intermittent.
Jul 13, 2023 9:45 PM UTC
Hi jules3,
Please check to see that the clients and or apps are the latest versions.
It may be a network problem.  Zoom has a network connectivity tool that can be run when you are experiencing these issues.
https://support.zoom.us/hc/en-us/articles/12997935825293-Zoom-Network-Connectivity-Tool
Aug 31, 2023 4:49 PM UTC
I have the same issue described above. I did the network connectivity test and there seemed to be no issues (can provide the log).
How do I solve the missing dial tone?
Feb 1, 2025 3:43 PM UTC
We are experiencing the same issue of no outgoing ring audio when connecting calls (internal or external), but only for 1 of our users and happens on his mobile app and desktop app!  Open to any other suggestions.
Feb 3, 2025 3:11 PM UTC
hi,
because it is only one of your users, it must be something different about the configuration for this user.
does this user use something different such as a particular brand and model of wireless headset, a different mobile device, a different version of an operating system, a different desktop and different operating system, a different version of zoom workplace app, wireless access or wired connection, etc.?
you can try completely uninstalling zoom desktop app and mobile client and reinstalling.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0065146
Aug 26, 2025 3:59 PM UTC
no use done this, do you have other solutions?
Aug 26, 2025 3:58 PM UTC
Hi has this issue ever been resolved? I'm experiencing the same now
Sep 10, 2025 3:36 PM UTC
Hello @jazz26,
Apologies for the delayed response. This message is to confirm receipt of the ticket you submitted to our technical team.
Your concern is currently under review, and further updates will be provided through ticket TS1988565 as they become available.
Thank you for your patience.
Sep 15, 2025 9:24 PM UTC
having same problem
