Aug 27, 2024 3:04 PM UTC
Needing to reboot Poly e350 phones in order for HOLD feature to work
We have the same extension on 3 Poly Edge e350 phones. Frequently, we are unable to retrieve a call that is on HOLD on another phone with the same extension without rebooting the phone. Since these phones are located in our Public Safety area, rebooting the phone can be problematic. Call Park is not an option since you need to enter a 3 digit code to retrieve the call and every second counts when answering an emergency call.  Phones are on version 8.2.1.0820.
Has anyone else encountered this problem?
Aug 28, 2024 10:27 AM UTC
hi peggy77,
First, I would suggest opening a zoom support ticket and a hp/poly support ticket.
Second, check to see if you have or have not enabled shared line privacy mode.  "Account owners and admins can enable a privacy feature for shared line groups or shared line appearance (call delegation). This allows shared line group and shared line appearance members to lock the call, which prevents others from picking up a held call, listening, whispering, barging, or taking over the call."
Third, Please describe your setup especially what zoom phone features you are using to permit the same extension on three e350 phones.
Enabling or disabling shared lines privacy mode
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0067654
Using shared line groups
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0068068
Changing shared line group settings
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0066890
Setting up nomadic emergency services
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0062169
Supported desk phone features
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0061373
Using call delegation (desk phones)
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0066070
Setting up call delegation
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0067483
finally, you may also find the poly quick start guide useful.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0057919
