Participant
February 17, 2022
Looking for ATA's that work with Zoom Phone?
When I find an ATA that allegedly works with Zoom Phone, I look to purchase and cannot find them anywhere, even on ebay. Anyone have some that are still available to purchase somewhere for Zoom Phone? Thanks!
    stevenrizAnswer
    Participant
    March 2, 2022
    I already had a Grandstream and Zoom is working with me to get it set up. Just had to sign a form stating I am using an unsupported device.
    ted
    @stevenriz check out our Zoom Phone Certified Hardware:
    https://support.zoom.us/hc/en-us/articles/360001299063-Zoom-Phone-certified-hardware
    Hope this helps!
    stevenrizAuthor
    Participant
    February 17, 2022
    Thanks Ted. Let me try one of these out and see how they work!!
    stevenrizAuthor
    Participant
    February 17, 2022
    It was the Poly that I prefer but cannot find them .. checking Audiocodes...
    FORE-Craig
    Expert
    Expert
    February 17, 2022
    Check with @BrandonS !
    He was working on the same issue:
    https://community.zoom.com/t5/Phone-System/Unsupported-analog-adapters/m-p/30956
    Participant
    February 17, 2022
    I have the Poly OBi302's and got them from voipsupply.com.
    stevenrizAuthor
    Participant
    February 17, 2022
    backordered wherever I look or it is priced by double.
    BrandonS
    Community Champion | Partner
    February 17, 2022
    I recently got a Grandstream 801 to work for a fax machine.  The biggest issue was back and forth with Zoom support for about 2 weeks to get them to enable generic SIP devices for my client's account.  They made me provide documentation and specifications proving the device supported TLS and various protocols.
    I also waited about 30 days for delivery of a Poly Obi recently.
    stevenrizAuthor
    Participant
    February 17, 2022
    Thanks for the info! The Grandstreams are so much cheaper and I've used them in the past with other providers. LGB!  (hope that doesn't offend you!)
    Thanks again Branson!!
    stevenrizAuthor
    Participant
    February 17, 2022
    ask you this, was the back and forth because they were having you try things over and over until it worked? Or do you think they can now do it quicker since they've already done it?
    BrandonS
    February 17, 2022
    It was just pushback from them and difficult to get them to approve enabling generic SIP devices.  I thought it would be a simple ask, but then they wanted to know what kind of device and documentation showing that is does TLS and other protocols.  Once they enabled it I was able to get it working in a few minutes.
    stevenrizAuthor
    Participant
    February 17, 2022
    Thanks. If you have a ticket number, I can reference it when I call.
    BrandonS
    February 17, 2022
    ticket# 13108504
    stevenrizAuthor
    Participant
    February 17, 2022
    THANK YOU BRANDON!
