Is there a separate volume control for the keypad? | Community
psquared1976
  • February 22, 2023
  • 72 views
My company uses the Polycom CCX700 series phones as Zoom Appliances.  Does anyone know of any way to turn down the keypad volume?  When you are on a call and you need to turn up the volume to hear the speaker, the next time you dial out, the DTMF tones are freakishly loud.  I know the solution is to turn the volume down, but is there any way to separate the call volume from the dial pad volume?
    Hello There,
    I do not think there is a separate button for keypad volume only. I have reached out to Poly to see if they have another method to do so.
    Will keep you posted
    I heard back from Holiday. They confirmed there is no way currently to have separate volume for Keypad vs the phone volume. They are open to filing a feature request if you would like to share your company name.
