Apr 23, 2024 7:34 PM UTC
I have a Axis A8105-E Intercom that partially works with Generic Sip. Help!
Good afternoon,
I have an Axis A8105-E intercom door camera, and I would like to get it working with Zoom Phone. After entering in all the information for the manual provisioning, and enabling sips I was able to get it provisioned with Zoom phone. I can make calls to the common area extension assigned to the phone, with the device automatically picking up and two way audio established. However, when I press the button and attempt to have the device call a Zoom extension, or even an outside phone number, the call rings, and when the recipient picks up the call just ends.
Are there any settings I am missing? Any insight or advice would be greatly appreciated.
IP-Man
Apr 25, 2024 3:28 PM UTC
I would suggest that you log a problem with Zoom Support at the site below, so support team can help you with the concerns, make sure you have call IDs /call samples that you can provide them so they can further check.
Apr 25, 2024 3:54 PM UTC
I took your advice and put a ticket in a moment ago. But this is a generic sip endpoint that is not on the supported hardware list. I am unsure how much support I will actually receive from Zoom phone support.
May 6, 2024 9:48 PM UTC
Did you ever get this working? We have AXIS C1410 speakers. Haven't been able to get them to connect to Zoom. Support wouldn't help because it's not supported hardware.
Jun 5, 2024 10:05 PM UTC
I had the similar issue with my C1410 speaker, where it would disconnect the call right after connecting. It turns out to be a codec selection issue.
Try the following and see if it solves your issue:
  • Under SIP settings -> Audio -> only select G.722, and unselect all others.
  • Under SIP settings -> Ports -> change TLS port to 5091.
  • Under SIP Accounts -> make sure to use TLS when registering to Zoom.
Jun 10, 2024 3:33 PM UTC
I checked the device and I don't see an option for G722 audio.
Jun 5, 2024 11:07 PM UTC
hi mvasquez20,
this appears to be a discontinued item.
AXIS A8105-E Flush Mount - Product support | Axis Communications
Accessories_Product Discontinuation Statement (axis.com)
maybe you might consider switching to zoom certified alternative such as 2n, algo or cyberdata?
Zoom Phone Certified Hardware
Jun 10, 2024 3:35 PM UTC
Unfortunately, Algo doesn't sell intercom cameras, and 2N cameras look not great based on the model we bought, and comments online. Checking Cyberdata's intercom, and the camera resolution is the same as 2N. Not seeing good door intercom options that are reasonably priced like the axis unit.
Sep 22, 2024 5:53 AM UTC
Is it possible that your device was reasonable because it is a discontinued item? Have you checked Amazon or eBay for one of the supported items? Maybe you can get it cheaper through there.
Sep 22, 2024 5:34 PM UTC
hi twiley,
i suspect the error message may be caused by issues with security settings and certificates.
please see zoom support article for details and some certified devices.
Zoom Phone Interop-certified hardware
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0074333
Oct 28, 2024 7:02 PM UTC
Did this get resolved? We are trying an Axis I8016
Oct 28, 2024 7:06 PM UTC
No this didn't get resolved, I tried what I believe is the I8016 as well.  Yielded the same result
Oct 28, 2024 8:53 PM UTC
Ours is reg to Zoom, however calls disconnect when you answer in ZP. ZP can call our device, and two way audio works. But not from calls from the device, they hang up when ZP answers.
Nov 18, 2024 6:18 AM UTC
Can confirm... The following settings work for the Axis A8207-VE Mk ii   as well.
Main Settings
  • Upgrade to the latest version  (version 12.0.98 min)
  • SIP Settings
    • Ports SIP 5090, TLS 5091, RTP Start 20000
    • NAT Traversal :    ICE Enabled   (Turn/Stun disabled)
    • Audio and Video :   Opus Enabled (disable all others)
    • Video Direction:   INACTIVE
SIP Account Settings
  • Transport Mode : TLS
  • TLS Version : Auto
  • Media Encryption: SRTP Mandatory
  • Default Cert
  • Verify Server Certificate:   Checkbox enabled
  • NO CHECKBOX on SIPS
  • Proxies,   Use TLS Transport
Dec 10, 2025 3:24 PM UTC
MVASQUEZ20 -   Are you able to provide the original settings that got the device to register?   Any resolution to this particular device?   We are currently migrating from Cisco to ZP and have a handful of generic sip devices out there.
