Mar 7, 2026 9:09 PM UTC
how to upgrade from pro workspace to pro plus (adding Zoom phone)
I cannot find a way to upgrade as described in the title line. Is this possible?
    Farah William
    Contributor I
    Contributor I
    Mar 8, 2026 11:19 AM UTC
    Yes, it should be possible, but the exact steps depend on the platform or service you’re trying to upgrade.
    In most cases, you can upgrade by going to Account Settings or Billing/Subscription in your profile. From there, there is usually an option to change or upgrade your current plan. If you don’t see that option, it may mean that upgrades can only be done by canceling the current plan first and then selecting the new one.
    If you could share which product or service you’re referring to, someone here might be able to give more specific guidance.
    ExpertswhoJohn
    Mar 9, 2026 8:31 AM UTC
    ​@cableguy ,
    Pro plus is not on the main pricing plan. if it has been made available to you then select it to update.
    Otherwise the upgrade from Pro is business.
    These are my options in the UK
    Then the account holder can go to Billing.
    https://us02web.zoom.us/billing
    All the best
    John Drinkwater
    Zoom Developer Champion
    https://lordzoom.com/go/hub
    cableguyAuthor
    Mar 9, 2026 1:57 PM UTC
    I was able to do it by upgrading to pro plus on my account page. Thanks for the comments!
