How do I set up incoming calls to go straight to voicemail? | Community
  • March 27, 2023
  • 87 views
I don't want incoming calls ringing on my phone or computer. How do I set this up? I currently have no business hours set and closed business hours settings say to send to voicemail if I'm on another call. However, I want it always to go to voicemail.
    Hi @pammy543
    for this under User settings of a user, disable everything under call handling. Click Edit
    This way all calls will directly go to Voicemail
