Oct 23, 2025 2:39 AM UTC
Help me pls
I’m a student using Zoom on my tab (Infinix XPAD 20) with android 15. After finishing one meeting, my audio completely disappears in the next meeting. Reinstalling Zoom temporarily fixes it, but it fails again immediately after the next meeting.
It worked fine for the first two days after installation, but this started right after a system update.
What I’ve tried so far:
Force-closing Zoom
Restarting the device
Clearing cache / offloading app
Reinstalling app
Joining a test meeting before classes
Zoom version: 6.5.12.33008
This issue makes it impossible to attend back-to-back classes. Please help or advise if there’s a workaround for mobile devices.
Thank you!
    Oct 23, 2025 10:22 PM UTC
    hi @Asriii
    You might try zoom workplace android app 6.6.0 available on google play.
    According to zoom release notes, current android release is 6.6.5 (34303) with 6.6.6 scheduled for 10/24/2025.
    Uninstalling and reinstalling the Zoom application
    Release notes for the Zoom Workplace app
    YaBoiB
    Nov 4, 2025 3:34 PM UTC
    Hello @Asriii ,
     Can you open a support ticket and let me know the ticket number? Zoom Engineering reached out to me about this issue. They need information from you that should not be in the Zoom Community.
