Apr 7, 2023 10:25 PM UTC
Click to Dial on Android does not have Zoom as an option
When we go to an applicable phone number and click on it, Ring Central, Phone, and another app pop up, but not zoom. Anyone have any ideas?
    YaBoiB
    Apr 7, 2023 11:43 PM UTC
    Hello @Guy2,
     You will need to change the default phone app in your phone. Here is some instructions on how to do this operation.
    https://www.howtogeek.com/798736/how-to-change-the-default-phone-app-on-android/
    Regards,
    Brandon
    Aug 14, 2024 1:47 PM UTC
    Zoom is still not being displayed as an option when I complete these steps. Other apps that don't even have voice services show up (like Webex) but no Zoom.  I have a Zoom phone license and can't complete calls outside the Zoom app. Frustrating.
    YaBoiB
    Aug 15, 2024 5:38 PM UTC
    @mcllc,
     Are you on a mac or windows machine or other?
    Aug 15, 2024 6:03 PM UTC
    Android
    Jun 18, 2025 3:25 PM UTC
    Can I still hope for a response to this?
    I've had the same infuriating issue. We switched from Vonage which worked *beautifully* with the promise from Zoom that everything would be as good and better. Nope.
