callerid parameter in zoom phone URI scheme does not work in android devices | Community
  • August 31, 2022
  • 46 views
I have a use case where I need to pass callerid parameter in the URI scheme to initiate outgoing call from zoom user's custom number instead of the assigned zoom number. So the callerid parameter is mandatory.
     zoomphonecall:+1234?callerid=+56789
The above URI scheme works from desktop web app but when I use the same from web android it says invalid phone number.
    FORE-Craig
    Expert
    Expert
    August 31, 2022
    Hi Aaqib,
    I would suggest posting your question in the Developer Forum under APIs and Webhooks, you'll reach a broader audience of technicians who may have experience with this.
    I hope that helps!
