Call Queue Opt Out Code Dialog Box Not Appearing
We have users part of the same set of call queues that are not presented with the Opt Out Code dialog box. The users are simply able to toggle out (of all queues, not talking about specific queues, only all) without selecting an opt out reason.
This is only an issue for a subset of the users and we cannot figure out why.
    dkasemanAnswer
    Participant
    March 29, 2022
    We found that if you have the opt out reason codes set on the Company info, it will show up for all users working from that site. (When you add the codes again, to the the call queue or the user, it presents a conflict and doesn't display all or any of the codes).
    IP-Man
    @kmateze , call queue reason code only works for users with a power pack license assigned.
    If my reply solved your discussion don’t forget to mark reply as the solution. Thanks!
    If this answer helped solve your question/issue, please hit the -Accept as Solution- button below.
    dkasemanAnswer
    Participant
    March 29, 2022
