Audio Library - Normal "ring" sound for inbound calls?
Does anyone have a good source on this or does zoom have a library to pick from?  Surprised I can't set what the caller hears while waiting to just a normal ring tone.  I don't want to play MOH or an announcement, just good old fashioned phone rings, human answers.
Thanks in advance all
    FORE-Craig
    Expert
    June 22, 2022
    Do you mean the ringtone that your callers will hear, or the ringtone that you hear when someone calls you? Your callers hear the standard ringtone for the country where you are located.
    FORE-Craig
    Expert
    Expert
    June 22, 2022
    dhasleyAuthor
    Hey thanks for respdonding I found where I was off.  I was being thrown off by the prompt on a call queue but I just found I can simply disable it, reading is good haha.
    FORE-Craig
    Expert
    Expert
    June 23, 2022
    You're welcome! I was wondering if perhaps you were referring to the Greeting Prompt. Haha. That was the first thing I turned off when we were setting up. 😊
