ZoomInstallerFull MSI silent deployment keeps popping the Command Line Help Switch box | Community
  • April 21, 2022
  • 38 views
I downloaded 5.10.3 ZoomFullInstaller MSI both for 32 and 64 bit.  I have no success deploying via SCCM or executing  through an elevated command prompt.  It gets stuck because it is waiting for a response.  Even if I run this command via elevated administrator CMD prompt, it keeps popping the command line switch help box. It won't silently install.
msiexec /i "ZoomInstallerFull.msi" /q /norestart Silent=true MSIRESTARTMANAGERCONTROL="DISABLE" ZRecommend="AudioAutoAdjust=1" ZoomAutoUpdate="true" ZNoDesktopShortCut="true" ZCONFIG="EnableSilentAutoUpdate"="True" ZCONFIG="SetUpdatingChannel"="0"
Please see attached picture, and advise. Thanks.
Please advise.  It only works if I only use, "msiexec /i "ZoomInstallerFull.msi"
    You have extra quotes in your string around EnableSilentAutoUpdate and SetUpdatingChannel
    It should read as follows
    msiexec /i "ZoomInstallerFull.msi" /q /norestart MSIRESTARTMANAGERCONTROL="DISABLE" ZRecommend="AudioAutoAdjust=1" ZoomAutoUpdate="true" ZNoDesktopShortCut="true" ZCONFIG=EnableSilentAutoUpdate="True" ZCONFIG=SetUpdatingChannel="0"
