Jul 14, 2025 6:42 PM UTC
zoom wont appear in microphone settings
im trying to configure zoom but none of the microphones work on my win11 hp, it keeps opening microphone settings, but zoom is not listed in microphone settings. i cant join or host any zoom meetings where my microphone will work. how do i fix this, or get my microphone to work on zoom, it works on other apps just fine.
storyhubAnswer
Jul 17, 2025 7:05 AM UTC
Open Zoom's audio settings and select the microphone and speakers. You may also need to turn off Bang & Olfsun audio enhancement because of HP.
storyhubAnswer
Oct 15, 2025 8:56 PM UTC
Hi @k40!
Given the time elapsed since we last heard from you, I've taken the liberty of marking the provided answer as the solution.
Have a fantastic day!
