Nov 5, 2021 7:53 PM UTC
Zoom won't install "Zoom Audio Device"
I'm trying to share my Pro Tools screen through Zoom. Supposedly when I check the box labeled "Share Sound" it should automatically install the "Zoom Audio Device", but it doesn't nothing happens. And for whatever reason, Zoom doesn't seem to make the driver available to download on it's own.
    Nov 18, 2021 3:53 PM UTC
    Hey @cmsuter, would you be able to take a screenshot of the contents of this folder:
    /Library/Audio/Plug-Ins/HAL/
    As the issue might be caused by some audio drivers using the same UUID for the Zoom audio device.
    Looking forward to your response!
    Feb 4, 2022 5:55 PM UTC
    I am having the same issue using LOGIC PRO X. I used to be able to change to the ZOOMAUDIODEVICE but it doesn't show up anymore -even though I have re-install Zoom countless times. Thank you
    Feb 20, 2022 12:46 PM UTC
    Updates?
    Jan 24, 2022 3:59 PM UTC
    Hi -
    I am having the same issue. Can you tell me more about the solution and the UUID?
    Thanks,
    Nicole
    Feb 20, 2022 12:50 PM UTC
    Any luck with it??
    Feb 20, 2022 12:45 PM UTC
    Hi, Did you figure out a solution yet?
    Feb 20, 2022 7:54 PM UTC
    No, I still need a solution to the problem.
    May 21, 2024 9:15 PM UTC
    I have the same problem!!! Please we need a solution!!!
    Aug 7, 2024 8:52 AM UTC
    Can someone help, please?
    I get a pop-up message requesting my password before clicking ok on the request for the Zoom audio device. However, it does not take it.
    Feb 1, 2025 6:28 PM UTC
    Did you get a reply? Same thing is happening to me.
    Dec 8, 2024 6:59 AM UTC
    Hello everyone! This helped.... go to this folder /Library/Audio/Plug-Ins/HAL/ and remove any suspicious audio driver (which in my case an old "soundgrid" waves audio driver. It was using the same UUID. You may get a way with removing all audio drivers and just reinstalling one by one when needed. But I would reinstall the zoom audio driver first and then the rest. Then you could do a process of elimination.
    Mar 19, 2026 10:23 PM UTC
    So I had the same problem.  Zoom wont install the ZoomAudioDevice unless it needs to.  So, join a meeting with someone.  Share your screen to the meeting and choose the option to share Computer Audio.  Then it will ask you if you want to install the ZoomAudioDevice.  Say yes, and it will immediately pop up in Audio Midi Setup.  Kind of silly, but not too painful.
