Sep 26, 2022 12:36 AM UTC
Zoom Window Locked With OBS Virtual Camera
I'm attempting to use Zoom with OBS, with OBS as a virtual camera outputting to Zoom. Using Windows 11. The window itself pretty much freezes and cannot be moved. It does show the video properly, but the Windows window comes to a grinding halt and cannot be moved. Will this integration be looked into by Zoom? Any settings to test here?
    Sep 26, 2022 7:47 AM UTC
    Since i have investigated that the version of Zoom that is failing is the latest and works with a slightly older version. So it's either bugged or I changed something so it won't complain.
    Sep 26, 2022 3:27 PM UTC
    I did downgrade and then as soon as I loaded a zoom meeting it popped up saying that it needed to upgrade. Not sure if I have access to some features. Would be great if Zoom tech support could let us know here if this is a real thing that they will fix soon. Millions of people use virtual cameras with OBS and other apps to colorize things better.
