Zoom will not connect no matter what. | Community
  • January 8, 2022
  • 7 replies
  • 64 views
I've reinstalled multiple times, checked all permissions to on, firewall is off, I downloaded the newest M1 version of Zoom. If I try to join a meeting or try to sign in it says "cannot connect check network".  My internet is working perfectly.
Any ideas how to fix this?
    Hey @Mazha, is the error you're prompt is there any specific error code with the 'cannot connect check network' error?
    I do have the very same problem with my Zoom Client (Application for Macbook). Zoom only tells you that you do not have a connection to the internet without error code, which makes the problem hard to locate. My Internet is working also perfectly fine and reinstalled the application several times.
    I do use my Google Mail (@gmail.com) by using the address and the Zoom password and not click on the Gmail Button. If I do so then I get the code 5003
    Unfortunately, Zoom on my Safari Browser always has a disturbed audio output - sounds like some broken radio on the voices, but still understandable.
    Due to these problems, using Zoom is really not preferred at the moment. So please let us find a solution.
    Thanks for help!
    Did you ever get zoom to connect?
    In the past, yes, but since a few months this problem has appeared. I also have got a new MacBook Air in January, I guess it is since then.
    I just used the Safari Browser again and it seemed fine this time. It could be that I used the Google Chrome Browser before (in contrast to what I have written initially). So maybe try this for now?
    Greetings
    Marc
    I have the same problem. This happens every 6 months or so for the past 2 years. Would like to have this corrected.
    I have the same problem; it's extremely disruptive! Don't know what to do...
