Zoom volume issue | Community
Zoom volume issue
  • April 16, 2022
  • 5 replies
  • 57 views
Hi.
Whenever join zoom meeting, without headset, I got volume issue
Maximum volume is too small, I can't hear properly. But when I turn on that speaker button on zoom, even the lowest volume is too loud.
    If you are using a Windows computer, you can check your Volume Mixer and see if Zoom's volume is set properly.
    And may I know what you mean by the speaker button on Zoom?
    This one. I'm using android  
    Just checking if my response solved your concern/question?
    Hi, I just wanted to check in and see if my response has been of help to you. If so, it will be greatly appreciated if you can click the 'Accept as Solution' button.
    This will be a great help to the community and to people who are having the same concern and are looking for answers.
    Sorry for late reply. I have hard time to access this forum. Login button is hard to find and I end up creating new ID with continously pop up appear
