Nov 13, 2025 4:11 PM UTC
Zoom using an iPhone15 -iPhone17 with USB-C adapter
If you're trying to record or Zoom meeting with a clean line-level audio into a USB-C iPhone (15–17), here's the setup Apple doesn't tell you about—but it works beautifully:
🔧 What You Need
  • Mixer or Line-Out source (e.g., audio interface, soundboard or line-out from a sound system)
  • 3.5mm cable (from source to where your Zoom is on your Iphone)
  • Variable attenuator (e.g., Nano Patch+ or SESMKP-27)
  • SR-C2003 cable (3.5mm TRRS to USB-C)
  • USB-C iPhone 15–17
🚫 What to Avoid
  • Apple’s USB-C to 3.5mm adapter — DAC-only, output only, no analog input support.
  • Fixed attenuators like Headset Buddy — Only works with lightning connections.
✅ Why This Works
  • USB-C iPhones accept analog input via TRRS when properly wired.
  • SR-C2003 cable is TRRS-compatible and routes signal correctly (supports microphone or line-out type).
  • Variable attenuator lets you match mixer or line-out output to iPhone input level (you control the level of attenuation).
  • Apple doesn’t offer input gain control—this setup solves that.
🧠 Bonus Tip
The Nano Patch+ or the SESMKP-27 (or similar attenuators are passive, durable, and gives you smooth rotary control over your input level.
📷 Signal Chain Diagram
source Line-out - variable attenuator - SR-C2003 adapter (line-in/microphone input) - Iphone15-17
