Nov 11, 2022 6:47 PM UTC
Zoom Recording Stuck Converting to .MP4
Help !!!   I failed to End Meeting after completing a one hour difficult presentation that I was recording on Zoom.   Is there any way to convert this to .MP4 file now.   It shows up in the Document \ Zoom folder local drive;  but the file name shows only "double_click_to_convert_02.zoom"
    Ohkawa
    Nov 13, 2022 2:32 AM UTC
    Hi, @Sabrina_Skeldon
    Refer to the following article to try a manual conversion.
    Troubleshooting local recording issues – Zoom Support
    Convert using the Zoom desktop client
    For versions 4.6.10 or higher, you can't convert local recording files by double-clicking the Zoom files. You must follow the steps below to manually convert the files:
    1. Sign in to the Zoom desktop client.
    2. Click the Meetings tab.
    3. Click the Recorded tab.
    4. Select the meeting topic with the local recording.
    5. Click Convert.
    If you still cannot convert, please check the files in the recording files folder.
    If the following three files are present, moving the recording.conf file out of the folder and then performing the manual conversion procedure may work.
    double_click_to_convert_01.zoom
    recording.conf
    Aug 25, 2023 8:34 PM UTC
    this process not successful for me
    Mar 20, 2023 7:24 PM UTC
    I am having the same problem.
    I tried the manual convert option by double_clicking the file, also tried open with transcode and it did not work. I have a 128MB file. Is there another application that can convert the .zoom file?  I also read that if you restart the computer, sometimes that will get the manual option to work.
    Ohkawa
    Mar 22, 2023 4:56 AM UTC
    @zaconline
    Have you tried the following methods?
    5. Click Convert.
    Aug 25, 2023 8:39 PM UTC
    task 0-5.0.24c292.0512: c:\users\raghunath user\documents\zoom\2023-08-25 22.03.51 rinku garg ji's personal meeting room\
    08/26/2023 02:07:49:122 : [Z1865]:2,622,0,622
    08/26/2023 02:07:49:630 : [Z1865]:0,622,0,622
    this comes as x coder error
    New Member
    Sep 25, 2026 5:56 AM UTC
    was that the date of my last zoom meeting
