Apr 20, 2026 2:38 PM UTC
Zoom Participants Not Being Heard Over Loudspeaker when 100+ connections (other Zoom callers can hear the audio)
When we have just a few Zoom participants everything works correctly - the Zoom callers can hear the audio from meeting room microphones and the Zoom callers can be heard in the room over the speakers. So by all indications our setup is correct - PC works, Windows setup is correct, Zoom setup is correct and connection to sound system (thru a sound board) is working correctly.
When we have 100+  callers we have been experiencing an issue where the Zoom callers can no longer be heard over the loud speakers. The users are being un-muted and asked to speak - they can be heard by other Zoom callers - just not over the loud speakers.
We have not tried using Host/Co-host setup which is our next step. Is there any other experience with this happening and/or recommended setup to try differently.
    lancetlcAnswer
    Apr 30, 2026 4:02 PM UTC
    Hey ​@Michael Lazarus
    Thank you for sharing.
    Possible Causes & Recommendations
    1. Audio Congestion / Network Latency
    Large meetings (100+ participants) can introduce significant data traffic.
    • Latency and buffering may delay or drop audio routed to the room's system.
    • Environments with high participant counts can cause packet queuing issues, affecting audio rendering on local endpoints.
    Recommendations:
    • Conduct a network test for bandwidth and latency. If possible, prioritize or isolate the meeting's audio stream.
    • Keep in-room participants and the Zoom client on a high-quality, dedicated network connection.
    2. Audio Routing & Loudspeaker Device Configuration
    When output sound is not correctly configured, audio may fail to reach the physical loudspeakers:
    • Common on Windows, especially using Realtek audio:
      • Audio enhancements may interfere with the output.
    • Zoom app may have misconfigured audio output or be muted at the app level:
      • Users have reported cases where the Zoom app output was muted in the Windows volume mixer, even though system audio functions normally.
    Recommendations:
    • In Windows Settings → Sound, verify the correct output device is selected.
    • Disable audio enhancements for the loudspeaker device.
    • Open the Zoom app Settings → Audio:
      • Use Test Speaker to confirm sound output is working.
      • Check that Zoom’s own app-level output is not muted in Windows Volume Mixer.
    3. Zoom Client Behavior with High Participant Counts
    Some behaviors may only surface in sizeable meetings:
    • In instances where many connections exist, Zoom may manage audio streams differently, potentially limiting or gating which audio channels are forwarded to certain endpoints.
    • Though Zoom’s documentation doesn’t explicitly mention thresholds, anecdotal evidence suggests large meetings can impact shared media performance.
    Recommendations:
    • Test using Host or Co-Host controls—especially for muting/unmuting—to see if changing roles affects audio routing.
    • Check whether using Zoom Rooms (dedicated AV hardware endpoints) or a wired broadcast output yields more consistent results.
    4. Audio Device Interaction / Echo Suppression
    Though not directly indicated in your description, issues may arise from device echo cancellation or multiple active audio endpoints:
    • Having multiple active audio devices (e.g., PC speakers, soundboard, video conferencing mic) in the same physical space can cause conflicting audio routing and potentially block sound output.
    Recommendations:
    • Ensure only one active audio output is routed to the loudspeaker system during the meeting.
    • Avoid unnecessary devices or mute individual elements when not in use.
    lancetlcAnswer
    Recommendations:
    Recommendations:
    Recommendations:
    Recommendations:
    aluyun
    May 8, 2026 10:56 PM UTC
    Hi ​@Michael Lazarus,
    Just checking in, have you had a chance to review the latest response to your concern?
    If it helped answer your question, feel free to mark it as the best answer so others in the community can benefit from it as well. If you still need any clarification or have additional questions, just let us know, we’re always here to help!
    May 9, 2026 2:27 PM UTC
    Thank you!
    aluyun
    May 11, 2026 5:11 PM UTC
    You’re most welcome. Thank you as well for your contribution to the community!
    Please feel free to reach out anytime if you have other queries or if you want to share Zoom related knowledge, information or best practice to the community.
