Nov 16, 2024 5:26 PM UTC
Zoom original sound not working
While playing flute on live, Flute sound is not audible even though Original sound is enabled.
    Nov 20, 2024 3:39 AM UTC
    I have the same issue.  Voice audio is OK  and we hear the first note of a musical instrument but none after that.  This seems to be an ongoing issue with Zoom since May,
    Nov 29, 2024 8:06 AM UTC
    I have the opposite problem on Mac. The instrument volume is fine, but the voice is barely audible.
    Nov 21, 2024 10:03 AM UTC
    If your flute sound isn’t audible during live sessions, even with Original Sound enabled:
    1. Use a condenser mic for better sound capture.
    2. Increase microphone input gain.
    3. Disable or lower noise suppression in your app.
    4. Test your setup with another device or platform.
    5. Use an audio interface for improved sound quality.
    Ensure all settings prioritize unfiltered audio capture.
