Jan 4, 2022 8:46 PM UTC
Zoom occupying audio even after meeting ends
For quite some time I am experiencing problems with my Bose QC wireless headphones that they don’t pick up sound from my phone, when connected to both phone and MBP.  After some research I have found out that it’s caused by Zoom which - even after ending meeting - sometime keeps sending no sound/white noise to the audio and therefore the headphones think that MBP is playing sound and don’t switch to the phone. This happens even hours after last meeting has ended.
When I exit Zoom the quiet noise noticeably disappears from the headphones and things start working normally.
I asked my collegues and 3 of them are having the same problem, so it seems like a common thing. Is this a bug in Zoom? Could it be fixed? Or is there some setting to avoid this?
    townsendwc
    Jan 4, 2022 10:21 PM UTC
    @MiDo420
    Thank you for sharing this feedback with our community team. This does sound like a bug.  Have you opened a support case for this?  If not, please use the link below to open a web ticket with the Zoom Technical Support Team.  It should generate a ticket for tracking purposes.  Would you mind posting that ticket number here once you do open a ticket?  I'd like to track it to see if other customers are also having this issue.
    Have a great day!
    --Bill
    MiDo420Author
    Jan 5, 2022 8:26 AM UTC
    @townsendwc thanks for the advice. I have raised the request: https://support.zoom.us/hc/en-us/requests/13122703
    Michal
    townsendwc
    Jan 5, 2022 2:33 PM UTC
    @MiDo420
    Thanks for opening the ticket.  I see that it is an open state and waiting to be assigned.  You should hear something from a support member within 24 hours.
    Jan 5, 2022 12:14 PM UTC
    I can confirm I've been encountering the exact same issue. It doesn't appear I can add any weight to the support request so I'm responding here.
    Mar 11, 2024 8:42 AM UTC
    Hi, any update on this?
    I have a Zoom meeting on a Monday morning for the whole company, on a handful of computers after the meeting ends the headsets (Poly Voyager) seem to be locked on the audio channel, I need to close Zoom, then pull out the Bluetooth dongle, repair the headset to the HiHi phone before I can use it again, this is very annoying, this does not happen on every computer I have just a selected few.
    It is as if the audio stream is still locked to the zoom meeting?
    Is there a patch for this? I have everything up to date but my employees are getting a little annoyed with this now.
    Thanks.
    townsendwc
    Mar 12, 2024 1:13 PM UTC
    @Philip_Walklett
    You may want to open a support case.  I am not aware of this being a mass problem for Zoom. Even you state this is on a handful of computers.  When we have seen this type of problem in the past, it was related to a HID driver problem or a device firmware problem.
    Sep 10, 2024 7:25 AM UTC
    Thank you so much for the suggestion.
    It sounds like a frustrating issue with your Bose QC headphones and Zoom. This does seem common; Zoom may continue sending audio signals after calls. Try updating Zoom, checking audio settings, or disconnecting and reconnecting your headphones. Reporting this to Zoom support might also lead to a fix in future updates. I want to read reviews for the domypaper.com website because I want to hire an essay writer. Can anyone help me, please? I will be thankful to you.
    Sep 23, 2024 3:43 PM UTC
    I have the same issue after zoom calls using my android phone. All my audios is either muted or toned very low. I can't control my media sound. When I click on my zoom app, it says back to meeting like I never left the meeting. It affects the overall media sound of my phone. I have missed many alarms I've set because of having only very faint sounds. When I fix it, it says I'm on a call. The only way I can fix it is by having to uninstall and install the app to be able to use my normal media sound. It is getting annoying.
