ZOOM interface stuttering is too much | Community
Hello when using ZOOM meeting, interface stuttering is too much. I want to know if it's a problem with PC specification or if it's because I'm using free version. I turned on Task Manager while using ZOOM and checked CPU RAM GPU, but it didn't overload me. Please guide me if you know how. Thank you.
Hello @everglowfilm
The free version has the same system requirements with the paid versions.
To check the system requirements when using zoom you may refer to this link:
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0060748
May we also suggest to update your system's drivers and your Zoom version to the latest.
Just to set your expectations if you will be sharing your screen, you may need a 4core processor or higher for a better experience.
If you need further assistance, please let me us know.
Have a great day!
This is complete bs, I have zoom uac-232 and on windows on a many core machine with high enough clocks I get constant stutters with WSAPI and it's really frustrating. I don't get the same stutters on mac and a SSL2+ interface on windows was perfectly fine. I think you shouldn't excuse your lack of good driver implementation on windows which in my opinion clearly shows.
This is complete bs , I have zoom uac-232 and on windows on a many core machine with high enough clocks I get constant stutters with WSAPI and it's really frustrating. I don't get the same stutters on mac and a SSL2+ interface on windows was perfectly fine. I think you shouldn't excuse your lack of good driver implementation on windows which in my opinion clearly shows.
