ZOOM has problem : Breakout room
Ask Question ?
zoom lincese Type 300 and 500
How many breakout rooms can be maximum?
 There was a problem with the Break out room, stuck during use.
causing the need to close the program and reopen it
    opbluelegend
    Contributor I
    November 5, 2021
    Up to 200 participants can be pre-assigned to breakout rooms. *The maximum capacities listed require a Large Meeting add-on.
    opbluelegend
    Contributor I
    Contributor I
    November 5, 2021
    You can create up to 50 breakout rooms. The maximum number of participants in a single breakout room depends on the meeting capacity, number of breakout rooms created, and if participants are assigned during the meeting or before the meeting.
    Thanks for the previous advice.
    I have an inquiry
    Zoom type 300 can create up  breakout rooms ?
    Zoom type 500 (add-on) can create up  breakout rooms ?
    How many help can there be? (co-host)
    How many meeting participants can be taken into separate  Breakout rooms per room?
    opbluelegend
    Contributor I
    Contributor I
    November 5, 2021
    50 breakout rooms are maximum capacity
    opbluelegend
    Contributor I
    Contributor I
    November 5, 2021
    thank you very much
    opbluelegend
    Contributor I
    Contributor I
    November 5, 2021
    accept as a solution please my 3 replys
    opbluelegend
    Contributor I
    Contributor I
    November 5, 2021
    thanks you🙂
