Apr 26, 2024 8:39 PM UTC
Zoom doesn't scale properly on an HD monitor with a scaling factor greater then 100%
I have a laptop with a resolution of 3840x2160. Scaling is set to 200. Zoom does not display properly unless the scaling is set to 100. Of course, this makes the menu bar on the bottom of the screen unreadable. I've tried setting scaling properties for the app with little success. It did work for a while, but a zoom update broke it.
Nov 1, 2024 4:43 PM UTC
Same here.  Running Linux + KDE Plasma + Wayland with zoom flatpak. Text in the chat is far too small.  The whole app should scale based on the desktop but does not.
Mar 17, 2026 4:53 AM UTC
Same problem on my ThinkPad X390 with 1920 x 1080 resolution and 150% scaling, running openSUSE Leap 16.0 and zoom 6.7.5. In this distro, System settings, Display & monitor, there’s a setting for Legacy applications (X11), with choices for Apply scaling themselves (default), and Scaled by the system. With the default setting, the New meeting window had the Start button off-screen and not accessible. I switched to Scaled by the system, and the New meeting window fits on the screen. I’ll try using this in a meeting tomorrow and see how it does.
Mar 17, 2026 9:15 PM UTC
I was in an openSUSE zoom meeting this morning with windows Scaled by the system, and things worked properly: windows fit the screen.
This problem seems to be only on Linux systems. This same ThinkPad booted to Windows 11 and running zoom 6.7.8 scales various zoom windows correctly. Zoom seems to have chosen to not include the scaling function in their Linux versions. Bummer.
Mar 29, 2026 6:37 PM UTC
I installed zoom 7.0.0 for openSUSE this morning, and it scales windows correctly. Nice. Thanks, Zoom.
