Aug 21, 2021 9:15 PM UTC
zoom does not work
I cannot log in to zoom or attend any meetings. This is the message:
"Check to make sure you're connected to a stable network that is not blocked by a firewall or proxy."
I have spent 3.5 hr with apple troubleshooting my mac. They said it's zoom. Any ideas?
Thank you
    Sep 9, 2021 12:57 AM UTC
    If you have a Mac - I had this issue for ages and was unable to resolve it. I finally did a little more looking, and found this StackExchange post that suggested uninstalling Zoom by using their uninstall file instead of putting the Application in the trash.
    https://superuser.com/questions/1671647/zoom-on-macos-catalina-hangs-on-connecting-gets-error-unable-to-connect
    I did this by going to Applications -> right clicking on zoom.us -> Show package contents -> open Contents -> open Frameworks -> use the ZoomUninstaller file.
    After this, I reinstalled and it successfully worked.
