Sep 28, 2022 9:46 AM UTC
Zoom - connection issues
Hello
I have. zoom Pro account which has worked fine on my MacBook Air until recently , now I continually get the attached message ,
 My Wifi is fine and I have no problems connecting to zoom on my iMac  so not sure what the problem is, I'd be grateful for any advice if anyone has had the same issue ,  many thanks !!
    ZOTAnswer
    Oct 7, 2022 12:58 AM UTC
    If you use VPN, please connect it and try to sign in to Zoom again.
    ZOTAnswer
    Nov 1, 2022 3:14 PM UTC
    What about if you don't use VPN?
    Nov 28, 2022 9:56 AM UTC
    Did you solve this problem?  I have the same problem.
